Mgerath
Aug 31, 2023Aspirant
RBR20
I use a RBR20 router in a mesh system with two satellite units. The firmware version is V2.7.4.24. Our service is cellular internet. I am in the process of adding four security cameras, 3 ADC-v724x a...
Mgerath
Sep 01, 2023Aspirant
The app is from Alarm.com. They initially pointed to the ORBI as the problem; however, the devices connect to the ORBI. I have pushed back to the dealer and Alarm.com to find the issue. The app recognizes that the devices are on the ORBI system and starts the install. It reaches 81% and fails.
I sign on to the ORBI router with Admin and do not see any logs that provide insight into the installation failure. I do not believe it is the ORBI.
What do you mean by big standard modem?
Thanks for your questions.
michaelkenward
Sep 01, 2023Guru - Experienced User
Cable, DSL and optical network termination (ONT) Internet don't need the fancy modems that come with "cellular internet".
What is the device that connects your router to the Internet?
If some devices connect while others don't I can't seen how this would affect your IoT things, but you never know.
- MgerathSep 01, 2023Aspirant
The ORBI router connects to a POE Adapter (Ubiquiti GP-A240-50G) that then connects to the cell dish on the roof.
