outdoor
Dec 09, 2022Aspirant
Rbr20connect to bell gighub
iM trying to get my orbi to connect to bell gigahub so i can use my own router Followed some instructions but not working On bell turn ofF unpl dnla turn off wifi turn on dmz Connect orbi ...
outdoor
Regarding # 2
I think that is what i'm trying to do?
on the Bell router/modem i disabled all wifi radios. I turned on DMZ (not sure what exposed host is) I added the MAC address of the orbi router to the active device. Turned off DNLP and UPnP. Connect orbi to Bell
Is that all i do on Bell router/modem? what should show in DHCP of Bell router/modem?
I'm not clear what to do on Orbi side? Do i change the router IP address to 192.168.2.2 (since Bell is 192.168.2.1) do i need to change IP from dynamic from ISP or something else? or is that it? then what reboot both? I've tried all this and not working
Dec 09, 2022Guru - Experienced User
Set orbi side to 192.168.1.1
Should be nothing else do to on the modem or Orbi side/
Might power OFF the modem and RBR for 30 seconds then back ON with the modem first then RBR. Top ring should turn OFF after 5 minutes or so, indicating the RBR has a connection to the modem.
- outdoorDec 09, 2022AspirantStill not working
