Mike-Mayer
Sep 14, 2018Aspirant
RBR20/RBS20 - Satellites not recovered after router reboot (Ethernet backuphaul)
Hi folks,
to improve the wifi coverage of my house, i've setup a mesh with one RBR20 and two RBS20 satellites. As the wifi connecitvity between the three floos is not that great and because I h...
Sep 14, 2018Guru - Experienced User
What FW is currently loaded?
What is the Mfr and model# of the ethernet switch if one is in the configuration.
Is Daisy Chain enabled on the router, disable this if it is while using ethernet back haul. Not sure if this will fix the app problem. This maybe an APP issue as well.
What mobile device are you using?
Do the satellites appear in the UI using a PC and browser logged into the routers web page?
Mike-Mayer
Sep 15, 2018Aspirant
Hi,
the switch is a Linksys LRT214, which is in the center. Also this Switch is the internet gateway. So the RBR20 is working in AP mode.
Deactivating dasy chain seems not to work :(
will try with setup from scretch with factory reset.
- Mike-MayerSep 15, 2018Aspirant
Reset and reconfiguration didn't help :(
Only thing tha happened, my router was killed and had to be restarted. When daisy chain was disabled, the setup didn't work. Now enabled again.
Maybe caused, by different DHCP-Server.
Which port and protocoll is used for the sync?
