Mike-Mayer
Sep 14, 2018Aspirant
RBR20/RBS20 - Satellites not recovered after router reboot (Ethernet backuphaul)
Hi folks,
to improve the wifi coverage of my house, i've setup a mesh with one RBR20 and two RBS20 satellites. As the wifi connecitvity between the three floos is not that great and because I h...
Mike-Mayer
Sep 15, 2018Aspirant
Hi,
the switch is a Linksys LRT214, which is in the center. Also this Switch is the internet gateway. So the RBR20 is working in AP mode.
Deactivating dasy chain seems not to work :(
will try with setup from scretch with factory reset.
Mike-Mayer
Reset and reconfiguration didn't help :(
Only thing tha happened, my router was killed and had to be restarted. When daisy chain was disabled, the setup didn't work. Now enabled again.
Maybe caused, by different DHCP-Server.
Which port and protocoll is used for the sync?
