Mike-Mayer
Sep 14, 2018Aspirant
RBR20/RBS20 - Satellites not recovered after router reboot (Ethernet backuphaul)
Hi folks,
to improve the wifi coverage of my house, i've setup a mesh with one RBR20 and two RBS20 satellites. As the wifi connecitvity between the three floos is not that great and because I h...
Sep 15, 2018Guru - Experienced User
Does the Linksys router have any IGMP Procols that can be disabled? Orbi doesn't seem to like IGMP on manages switchs/routers. Others have said that they've disabled IGMP protocols and seems to help them...
Also you may need to set up the Orbi in AP mode if your going to run with a main host router in front of the Orib system. Daisy chaing needs to be disabled when running wired back haul.
