adamber
Mar 21, 2022Aspirant
RBR20/RBS20--Connecting with Spectrum WiFi6 Router
I recently upgraded to a Spectrum WiFi6 router but am still have connection issues (non-existent or buffering) with a TV on the other side of my house (one story--2000 sq. ft.) as well as a TV that's...
Mar 21, 2022Guru - Experienced User
If your ISP Modem already has a built in router and Wi-Fi, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
adamber
Hi Furrye38...don't know what the firmware version is and I can't plainly see what the mfr. is on the modem (it's separate from the router). It's a Spectrum branded unit with a model # of EU2251. It sounds like from what you say that the piggyback idea is not a good one and I should look for a different solution--either something Spectrum can provide (i.e. a "pod") or using the Orbi system alone (and taking back the Spectrum router), the latter of which was recommended by a Spectrum tech when I called. The satellite would be placed about 30-35' away from the router if I go that route. In any case, I'll look at the links you sent. Thanks.
