Retired_Member
Apr 20, 2020RBR20/RBS20 2.5.1.16 firmware observations
Hi all, I upgraded my RBR20 and RBS20 to 2.5.1.16 firmware last week. Previously they were running 2.3.5.38 firmware. A couple of observations: The release notes say "Enhances the device ...
Retired_Member
Apr 20, 2020
Retired_Member wrote:I have a long background in wireless networking and tried every setting and combination of settings imaginable, including clean installs.
No dice until the firmware upgrade and bingo - all good. So far it's only a dirty install but everything is fine. I don't use any of the content management or filtering features for what it's worth.
Betting there are improvements in the code base that won't be mentioned in the release notes.
what you don't mention is why you upgraded?
Retired_Member
Apr 20, 2020I've got backup routers if it failed or wasn't reliable and confined to home with this virus kerfuffle, so why not?
As it turns out it's a big improvement for me. So just sharing the experience....
- Retired_MemberApr 20, 2020
Retired_Member wrote:I've got backup routers if it failed or wasn't reliable and confined to home with this virus kerfuffle, so why not?
perhaps that's what the 'living on the edge' crowd needs is a bunch of extra routers sitting around to remedy that itch to upgrade....
thanks for sharing
Someone has to be on the edge.
Acknowledging that it's unfortunate installing released Netgear firmware is considered (with some justification) to be bleeding edge.
- FURRYe38Apr 20, 2020Guru - Experienced User
Its only consider "bleeding edge" to some. I would not take this as applicable to everyone who has the latest and greatest loaded. FW works for some and some maybe not to so much. Problems need vetted out properly which included resets and reverting FW as a last resort during troubleshooting processes.
Retired_Member wrote:Someone has to be on the edge.
