sailon1
Nov 09, 2020Follower
RBR20/RBS20 Wifi interrupts?
Our church has an RBR20 router and 3 RBRS Satellites. We placed an RBR20 Satellite in our church balcony to be able to connect a new computer that runs our new live streaming system. We are getting s...
Nov 09, 2020Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
