18rabbit
Nov 13, 2019Aspirant
RBR20,working fine over a year on Comcast Voice Modem . Drops Internet after 2nd ATT modem install
My Orbi RBR20 router with 2 satelites has been working fine for over a Year. Recently in California my county was subject to forced county wide electric shut off. My Comcast modem and Orbi router wer...
- Nov 13, 2019
Tnx for the information.
I am not totally WIFI savy and your multiple solution attemps sound complicated due to the terminology. I believe I am on the right track, then when you say shut of all WIFI signal (radios) from the ATT modem. I do see a couple of new ATT WIFI addresses on ORBI APP when the ATT modem is live.
I will try the ATT WIFI disable proceedure as posted on netgear youtube video and see if that takes care of issue. I'll read your response again to see if I can interpret the steps you recommended better.
TNX again
18Rabbit
Nov 13, 2019Guru - Experienced User
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly. Then use the Orbi router in router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
18rabbit wrote:My Orbi RBR20 router with 2 satelites has been working fine for over a Year. Recently in California my county was subject to forced county wide electric shut off. My Comcast modem and Orbi router were both on battery backups. both systems kept running but no Internet access due to Comcast signal failure.
Decided to connect a new Att UVERS modem with WIFI on a ATT land line that suposedly would remain work. Ordered new ATT UVERS modem to connect to my land line assuming I would have a backup WIFY system on the ATT UVERS with battery backup on the modem.
After install of ATT modem I tested new WIFI and it worked fine. The comcast WIFI was up and working with the ORBI 20 and satellites.
I have a video security system on the two statellites and it started to fail. After checking ORBI I found the internet connections had failed but the equipment was still connect to the ORBI WIFI, veryfied by checking the MACs of my cameras. The ORBI device mgr did shoe my send and last satellite with a orange status lite verses the normal green status lite.
I found that if I unplug the UVERS modem the Orbi system will start to work and indicate that I have Internet access.
I notice on the support page a link to a video showing how to disable the ATT UVERS WYFI signal on the modem. I am assuming someone has had a similar problem as I am have with the two active WIFI Comcast and ATT signals and resolved the problem by disabling the ATT WIFI signal and you then would connect the ethernet port for internet access.
By unplugging the ATT modem I effectivelly disabled the WIFI signal; this does resolves the problem of no internet access on my ORBI systems. Question is this the only solution to operating the ATT UVERS modem and the ORBIsystem Compact WIFI extender simutaeously? I will use the ATT disable configuration if this is the only solution.
Thanks for any help on this.
18rabbit
18rabbit
TNX again
18Rabbit
- FURRYe38Nov 13, 2019Guru - Experienced User
Simplest is best. Yes, the wifi on the ISP Modem should be disabled mainly. You'll only need the Orbi wifi as you main wifi to connect all your signals too.
18rabbit wrote:Tnx for the information.
TNX again
18Rabbit
