18rabbit
Nov 13, 2019Aspirant
RBR20,working fine over a year on Comcast Voice Modem . Drops Internet after 2nd ATT modem install
My Orbi RBR20 router with 2 satelites has been working fine for over a Year. Recently in California my county was subject to forced county wide electric shut off. My Comcast modem and Orbi router wer...
- Nov 13, 2019
Tnx for the information.
I am not totally WIFI savy and your multiple solution attemps sound complicated due to the terminology. I believe I am on the right track, then when you say shut of all WIFI signal (radios) from the ATT modem. I do see a couple of new ATT WIFI addresses on ORBI APP when the ATT modem is live.
I will try the ATT WIFI disable proceedure as posted on netgear youtube video and see if that takes care of issue. I'll read your response again to see if I can interpret the steps you recommended better.
TNX again
18Rabbit
18rabbit
Furrye38guru
I looked at your 2 links on double Nat and Access Point.
Very interesting but not quite my configurations. But will explore if my Kill ATT UVERS WIFI doesn't work.
Tnx Again
18Rabbit
Nov 13, 2019Guru - Experienced User
Hopefully the disabling of wifi is all thats needed.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
18rabbit wrote:Furrye38guru
Tnx Again
18Rabbit
