virtual008
May 04, 2021Initiate
RBR40 - Bricked? Won't Factory Reset?
So everything was fine and just thought I would reboot my system because I hadn't done it in a while. Oops..That was a mistake. My main route seems to be bricked. I can't find the SIDD and the pow...
May 04, 2021Guru - Experienced User
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
Need to press the reset button for 30 seconds then release, then it send to PUT the command and upload the FW.
If this fails then your RBR is bad and needs to be replaced.
Good Luck.
