alexsos
Jul 10, 2020Aspirant
RBR40 - frequently lost connection - over payed routers?
Hi, I've been having the same problem for months now. I'm using radio internet access and then use my Orbis inhouse. RBR40 and 1 satellite. The problem is that frequently I'm losing internet connect...
alexsos
Circle _ I will check once my test with TP-Linkmis over and then disable
How about Armor? Same risk?
john442 wrote:Are you running Circle parental controls? This has cause random internet drops...
john442
Jul 10, 2020Tutor
Not sure on Armor, not running it.
I know Circle causes issues... I had tons of drops, valided with Charter that my modem had no disconnects. Disabled Circle..haven't had a disconnect since....before at least 2-3 a day. Spent hours debugging it...
I do have an open support case for it....
- alexsosJul 11, 2020Aspirant
Ok, Circle switched off fully. We shall see if that helps.
Thank you,
Alex
john442 wrote:Not sure on Armor, not running it.
