Notanetworknerd
Jan 17, 2023Follower
RBR40 - how to determine bandwidth consumption
Hello, NetGear community! I'm having a "discussion" with my ISP, who claims that I'm using a ton more data than I have historically used. But they're also claiming that they can't "see" what MAC ...
CrimpOn
Jan 17, 2023Guru - Experienced User
Notanetworknerd wrote:
But they're also claiming that they can't "see" what MAC is being so greedy.
They are correct. Residential router use Network Address Translation (NAT) to give the appearance of all activity coming from a single IP address. https://en.wikipedia.org/wiki/Network_address_translation
plemans is right. Customers have been asking for this capability since 2018 and it has the most support of any suggestion:
https://community.netgear.com/t5/Idea-Exchange-For-Home/idb-p/idea-exchange-for-home/tab/most-kudoed (435 Likes plus 127 on a similar request).
Aside from the process of elimination, there is another way to search for the "offender":
- Use the debug feature to capture LAN/WAN traffic
On the Orbi debug page, http://orbilogin.net/debug.htm,htp://orbilogin.net/debug.htm
Enable LAN/WAN packet capture
Start Capture
Wait an hour or so
Save Capture - This will save a file debug-log.zip to your computer.
There are two files of interest: lan.pcap and wan.pcap
Extract them from the zip file. - Use a program designed to read pcap files (Wireshark is free for Windows)
- Open either wan.pcap or lan.pcap and selecct the Statistics option "Conversations"
- There is a chance that something will "pop out" in the sense of "WTF? What's all this talking to *&^%.com"???
- I would not try this when there are a bunch of devices streaming video and "Zooming" because those will generate very big Conversations.
