Fergie2
May 08, 2020Aspirant
rbr40 - need advise on setting the Orbi up with a new modem.
I have the RBR40 which is two years old. I am switching from Spectrum to ATT Fiber 1000 this weekend. My Orbi is all set up with the Spectrum modem and working fine. Can some advise as to what I ne...
Fergie2
If my objective is simply to have a wide coverage of internet services over my property at the fastest speed possible, which route should I go down?
May 08, 2020Guru - Experienced User
30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Option 3 would be easiest.
Fergie2 wrote:If my objective is simply to have a wide coverage of internet services over my property at the fastest speed possible, which route should I go down?
