billprice
Nov 06, 2019Aspirant
RBR40 - Printer offline and network shares dropping
I have an RBR40 with two RBS20 satellites. Everything shows connected and working fine in the admin console. However, I am unable to ping devices connected to one of the satellites while connected ...
Nov 06, 2019Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
billprice wrote:I have an RBR40 with two RBS20 satellites. Everything shows connected and working fine in the admin console. However, I am unable to ping devices connected to one of the satellites while connected to wireless through the main RBR40. This seems to be resolved by rebooting the network.
Other devices connected wirelessly to the satellite are able to print and see network shares with no issue.
Seems to be a bug/issue with the Orbi itself.
- billpriceNov 07, 2019Aspirant
V2.3.5.30
UBEE e31u2v1
What is the size of your home? Sq Ft?Office - <1500
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.25 feet
2.4 ghz - Auto 5ghz - 48
Any Wifi Neighbors near by? If so, how many?1 - near, but not overlapping.
They are
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).They are.
As I said - rebooting the network seems to allow the wireless device to see the remote satellite and connected devices. The issue is not with connectivity dropping. The devices on the satellite are rock solid, always connected to internet and can see other resources on the network (another network printer), but cannot see the wireless devices either. When it is working then the satellite can see a network share I setup for testing on the wireless device connected to the main router and vice versa. However, usually after a few hours, the connection drops and cannot be reestablished. This also occurs if the wireless device leaves the network and rejoins (I leave for a meeting and come back). SUPER FRUSTRATED.
