billprice
Nov 06, 2019Aspirant
RBR40 - Printer offline and network shares dropping
I have an RBR40 with two RBS20 satellites. Everything shows connected and working fine in the admin console. However, I am unable to ping devices connected to one of the satellites while connected ...
Retired_Member
Nov 07, 2019When was the last time your system was working fine?
When did you get V2.3.5.30 firmware? How did you get it?
- billpriceNov 07, 2019Aspirant
It has dropped since I set it up. Prior to setting up the share we occassionally had printer issues but those were transient and not critical enough to investigate properly. The network share is for a shared instance of Quickbooks and causes the remote session on wireless to hang and drop when Orbi freaks out. Meanwhile the local instance, which is on the satellite, has a rock solid connection to internet. We also run VOIP through the satellite and no issues at all.
The firmware was updated through the auto update tool. I check for updates monthly.
I went back through my setup and made sure that I have address reservations setup with MAC and name configured. I did not change anything but hit 'save' when exiting the settings screen. The system did not reboot. But then the network share connected and was pinging successfully again. Could be a coincidence - the network share comes up randomly and does connect while on wifi, but then drops after a few minutes.
And yes, I know connections to network shares can be a bit flaky under wifi and Quickbooks is a bit sensitive to small amounts of packet loss to network shares - BUT this issue the network share goes down completely, disconnects, and unable to even ping the server at all - destination host unreachable - until the system reboots or a random interval of time (several hours typically) passes.
- Retired_MemberNov 07, 2019
Without a stable operating period, it's hard to say what the issue may be.
There have been known issues with V2.3.5.30 . You may try to revert (download page) your firmware to an older version.
Tip: Stop performing manual updates. NG pushes updates automatically they contain major revisons.
Good luck
Revert firmware? Good Luck?
The share went down again between posts. Then came back up.
I am just going to connect the server directly to the router. Problem solved.
