caiosa
Sep 28, 2020Aspirant
RBR40 - Problem when using 2 wall plug satellites RBW30
Hi, I'm having a lot of problems when using my Orbi system. At the moment, I'm only using one satellite because when I add the other on the network, I see a lot of packets drops and high late...
Sep 30, 2020Guru - Experienced User
What happens if you power OFF the working RBW and leave the other RBW online?
What happens if you swap RBWs around for the one that seems to cause problems. Does the problem follow or not?
Is Daisy chain enabled on the RBR?
caiosa wrote:Hi,
At the moment, I'm only using one satellite because when I add the other on the network, I see a lot of packets drops and high latency with huge variation.
Does anyone faced the same problem?
My house Is big so I need the extra satellite to better coverage
Can someone point me where I can identify the logs for trobleshooting?
Regards
Caio
caiosa
Sep 30, 2020Aspirant
FURRYe38 the whole network became a little better but still some drops and high latency.
With only the RBR40, the network is good but I can reach some devices that are far from the RBR40.
Tried several locations but still no success.
Problem is that I can't reset both RBW30
- FURRYe38Sep 30, 2020Guru - Experienced User
What do you mean you can't reset the RBWs? You can reset them by pressing the reset button for 15 seconds then release. Should be able to re-sync them.
So did swapping the RBWs around change any thing or leaving just the 1 RBW online and not both?
