caiosa
Sep 28, 2020Aspirant
RBR40 - Problem when using 2 wall plug satellites RBW30
Hi, I'm having a lot of problems when using my Orbi system. At the moment, I'm only using one satellite because when I add the other on the network, I see a lot of packets drops and high late...
caiosa
Sep 30, 2020Aspirant
FURRYe38 the whole network became a little better but still some drops and high latency.
With only the RBR40, the network is good but I can reach some devices that are far from the RBR40.
Tried several locations but still no success.
Problem is that I can't reset both RBW30
Sep 30, 2020Guru - Experienced User
What do you mean you can't reset the RBWs? You can reset them by pressing the reset button for 15 seconds then release. Should be able to re-sync them.
So did swapping the RBWs around change any thing or leaving just the 1 RBW online and not both?
