iceman_nik's avatar
iceman_nik
Follower
Dec 07, 2020
RBR40 - RBS20 Wired Backhaul Inquiry
I’ve got a question in terms of using satellites to connect through a wired backhaul to my router.
Currently I have my RBR40 connected to the ISP’s modem, then have an wired backhaul Ethernet that connects my RBR40 to the 1 of 3 RBS20s.
The other 2 satellites are then wirelessly connected to the first satellite.
Can I use the other Ethernet port on the first RBS20 to connect to my PC and use it as a normal wired connection?
I.e. If I’m using one slot for a wired backhaul then can the other slot still be used as a normal Ethernet connection?
I had been doing so successfully for quite a while but then randomly recently have had my entire connection (especially to 2 additional satellites that connect to the first RBS20) upstairs trip up every once in a while and I’m not sure if it’s related.
Thanks in advance!
