Wrathchild
Aug 12, 2021Aspirant
RBR40 - RBS40 - RBS50Y - RBS50Y link problem
I have RBR40 connected as livingroom, and my RBS40 is located housegarage. Then i add RBS50Y outdoor near garage RBS40. Other RBS50Y is my barn wall 60 meters apart. Problem is barn satellite connects...
Aug 12, 2021Guru - Experienced User
Might try this, power OFF the RBS40 for 30 seconds then back ON and see if the barn RBSY connects to other RBSY.
Is Daisy Chain enabled on the RBR? Under Advanced Tab/Advanced Settings/Wireless Settings
Wrathchild
Does not work booting RBR40. Also daisychain is enabled. I tried to lower power to 50%, but it didn't work. It connect to 2ghz.
