TallTell's avatar
TallTell
RBR40 - Update Firmware Discrepency
I have the RBR40 mesh with 2 Orbi Satelites.  I received an email on March 15, 2020 stating there is a new version of firmware out v2.3.5.34.  When I go to the router settings, it states my firmware ...
  • Retired_Member's avatar
    Retired_Member
    Apr 09, 2020
    TallTell wrote:
    I wanted to make sure I was up to date.  According to my app I am.  Thanks for you reply.
    ok....in the future no need to worry or keep checking about firmware updates.
    when there is a critical update, NG will push it to you automatcially.  no action required on your part.
