TallTell
Apr 08, 2020Aspirant
RBR40 - Update Firmware Discrepency
I have the RBR40 mesh with 2 Orbi Satelites. I received an email on March 15, 2020 stating there is a new version of firmware out v2.3.5.34. When I go to the router settings, it states my firmware ...
- Retired_MemberApr 09, 2020
TallTell wrote:I wanted to make sure I was up to date. According to my app I am. Thanks for you reply.
ok....in the future no need to worry or keep checking about firmware updates.
when there is a critical update, NG will push it to you automatcially. no action required on your part.
Retired_Member
Apr 09, 2020
TallTell wrote:I have the RBR40 mesh with 2 Orbi Satelites. I received an email on March 15, 2020 stating there is a new version of firmware out v2.3.5.34. When I go to the router settings, it states my firmware version is v2.3.5.32. When I go to 'Check for Updates' it states 'No new firmware is available at this time.' I would assume .34 is the latest version. Why am not able to update to .34 from .32?
Aside from the fact that you received an email from NG, why do you want to upgrade your firmware??.
TallTell
Apr 09, 2020Aspirant
- FURRYe38Apr 09, 2020Guru - Experienced User
You can check NGs download site for updates and release notes and manually download and apply FW files if you want to as well.
Good Luck.
FURRYe38 wrote:You can check NGs download site for updates and release notes and manually download and apply FW files if you want to as well.
or...they can just leave things alone....its too crowded living on the edge
