pikkolomondano
Dec 03, 2018Aspirant
rbr40 + 2 satellite rbw30 lost wifi password
i ve this system orbi router rbr40 always connected in perfect condition and 2 satellite connected in 5ghz (2 meter of distance one satellite form other with a big wall in the middle).
2,4 and 5 g...
ekhalil
Dec 03, 2018Master
pikkolomondano wrote:
.............Problem is that on 2nd satellite wifi radius, when i try to connect.... wifi network is seen correctly but it's impossible to connect because satellite tell me wifi password is incorrect.
This can happen because of loss of IP connectivity between the Satellite and Router. Please try the following:
1. Please set IP address reservation for the Satellite in the DHCP reservation.
2. Please make sure that you don't have 2-router setting. PPlease make sure that your ISP modem/router is bridged and does not act as a second DHCP server.
pikkolomondano
Dec 06, 2018Aspirant
i bridged modem/router, but after a couple of hours problem is starting again.
Now i ve made an hard reset, put orbi router in AP Mode and set fixed ip adress on modem/router for orbi router and satellites. Last i put dhcp lease on 48 hours.
For now it seems to be ok..... but i want to test it for a week.... to be sure.
- ekhalilDec 06, 2018MasterGreat. This should work.
Please keep us updated of how it goes.
Good luck.
