Bgkhna
Aug 17, 2021Aspirant
RBR40 / RBS40 upgrade
Have a Mesh Orbi
RBR40 / RBS40
Should /could I upgrade to new Orbit 6 GB?
Thx
Bgkhna wrote:
Have a Mesh Orbi
RBR40 / RBS40
Thx
That's your call. But don't expect much feedback here.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Orbi - NETGEAR Communities - plemansGuru - Experienced User
should you? debatable.
could you? yes.
the more important question is would you notice a difference and would the $ be worth it?
Does the current RBR40 provide the coverage and speeds you need?
Or are you having problems with it? and if you're having problems, what issues are you having?
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-axThank you.
Bgkhna wrote:
Have a Mesh Orbi
RBR40 / RBS40
Thx
