Bgkhna
Aug 17, 2021Aspirant
RBR40 / RBS40 upgrade
Have a Mesh Orbi RBR40 / RBS40 Should /could I upgrade to new Orbit 6 GB? Thx
Aug 18, 2021Guru - Experienced User
should you? debatable.
could you? yes.
the more important question is would you notice a difference and would the $ be worth it?
Does the current RBR40 provide the coverage and speeds you need?
Or are you having problems with it? and if you're having problems, what issues are you having?
