Talk2Mike
Dec 29, 2020Apprentice
RBR40 2.6.1.38 firmware manual upload | 400 Bad Request Error
My Orbi RBR40 is already on 2.6.1.36 but I see 2.6.1.38 is available on the Netgear support pages, even though not offered in the automatic update page in the router. If I try to perform a manual up...
- Dec 31, 2020
Found the error. I was trying to load the RBS40 firmware not the RBK40 firmware. In fact i already have the latest RBK40 firmware!
Dec 30, 2020Guru - Experienced User
Be sure you are using the right RBR FW file.
Try a reset.
Talk2Mike wrote:Using Firefox has the same response as using all the other browsers I tried. The RBW30 is already on the current released firmware and the RBK40 had the version 2.6.1.36 firmware installed manually without this error.
I am loathed to reset unless a simpler solution can be found. Maybe this is a bug of V2.6.1.36?
vajim
Dec 30, 2020Master
right?
- Talk2MikeDec 31, 2020Apprentice
