viperamd64
Jul 12, 2019Aspirant
RBR40 400 bad request - server does not support operation request by your client
Loaded new firmware a few months or so ago on my RBR40 (it is an RBR40 not RBR50) and accessed it today and saw another firmware update msg, so hit update and got a msg "400 bad request. This server...
- Jul 13, 2019
Out of sheer frustration, I tried accessing the router using Microsoft Edge (had previous been using Chrome and Firefox) and amazingly it worked!! Not sure why a different browser would make a difference (maybe an extension issue?) Regardless, I was able to access and reconfigure and load new firmware. Thanks for the feedback from everyone
michaelkenward
Jul 13, 2019Guru - Experienced User
You could get the firmware here and update manually:
RBR40 / RBS40 Firmware Version 2.3.5.30 | Answer | NETGEAR Support
There is support for the Orbi WiFi System, including a manual, somewhere at the end of this link:
>>>> Orbi RBK50 | WiFi System | NETGEAR Support <<<<
See the section Manually Update Firmware.
