SGerman
Jan 05, 2021Aspirant
RBR40 and 2 Satellites will not detect 2 Macbooks, but recognizes 15 other devices
I have an Orbi RBR40 Tri-band WiFi Router and 2 satellites running v2.5.1.22 and v2.5.1.16 respectively. Router is connected to Xfinity modem and has consistently been running about 16+ devices. Acco...
SGerman
Thank you for the response... the modem is a Netgear CM500 and both Macbooks are running Catalina v10.15.7. We've tried all the power downs and yes the Macbooks both still get IP address with no connections to the internet. WiFi status on both Macbooks show green and I can see packets received. We ran a diagnostics on both Macbooks with Apple care support and shows no internet connection. But both Macbooks will connect to a hot spot and the neighbors WiFi with no issues, just not ours. No other issues with any of our other 16+ devices, as I mentioned includes another Macbook. Still at a loss.
Jan 05, 2021Guru - Experienced User
16 other devices working on Orbi and only these two mac books using 10.15.7 would kind of point to the mac books having a problem.
Check the mac books to see if the networking setting are getting a DNS address from the Orbi router, maybe a 192.168.1.1 address. If you don't see anything in DNS, this would be a cause of the macs not getting internet services.
- CrimpOnJan 05, 2021Guru - Experienced User
Did these two MacBooks have a software update recently?
Is Access Control turned on?
Do you use the Orbi "app" or the Orbi web interface to manage the Orbi system?
