unionjosh
Dec 07, 2020Aspirant
RBR40 and Chromecast Audio Device
I have an Orbi system setup in AP mode with a FIOS Gateway (wireless antennae disabled). I've successfully set up multiple chromecast audios and groups in the past. I have a new soundbar with chromec...
Dec 07, 2020Guru - Experienced User
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
I would try option #2 first, then #3 next.
unionjosh
Dec 08, 2020Aspirant
Thanks for the reply.
I think I may have explained it poorly. I believe I'm already connect via method #3. I attempted #2 unsuccessfully a few months ago, though I'll try it out after remote learning is done.
