Ultraklassic
Jan 12, 2022Aspirant
RBR40 AND DOCSIS 3.1
I have a new Arris SB33 DOCSIS 3.1 modem connected to an Orbi RBR40 router system with 3 satellites. I suscribe to Vyvebroadband for my cable needs and I have the 1Ghz download package. My Arr...
Jan 12, 2022Guru - Experienced User
Would be the modem. You'll need to contact the Modems Mfr for additional help and support regarding there modem. Also keep in contact with your ISP. They'll need to check the signal on the lines up to the modem and check cableing.
Good Luck.
