Ultraklassic
Jan 12, 2022Aspirant
RBR40 AND DOCSIS 3.1
I have a new Arris SB33 DOCSIS 3.1 modem connected to an Orbi RBR40 router system with 3 satellites. I suscribe to Vyvebroadband for my cable needs and I have the 1Ghz download package. My Arr...
CrimpOn
Jan 12, 2022Guru - Experienced User
Ultraklassic wrote:
..........or is my Cable provider lying to me regarding their ability to deliver DOCSIS 3.1????:smileyfrustrated:
This modem has only one LED, which uses different colors to indicate status. See page 9:
I see two possibilities:
- What Arris describes as 'blue' may appear 'green' to you.
Color tests are widely available on the internet. They are quick and sort of entertaining. I found this one almost fun:
https://www.colorblindnesstest.org/ - There is a problem with your cable drop which affects some of the frequencies and the ISP is unaware of it.
Are you able to log onto the modem? (Page 15 of the manual) and navigate to page 18? That is supposed to indicate the status of the modem.
Ultraklassic
Jan 14, 2022Aspirant
Been busy at work guys so thanks for the replies. I have not called the ISP yet but I did log into my modem and this is what I see. Do these numbers look acceptable???
My modem is still showing a green light indicative of DOCSIS 3.0 when it should be blue for DOCSIS 3.1. I will check my cabling for crappy splitters to rule that out as a potential communication issue.
And BTW, I passed the Color Blind Test.... LOLđ€Łđ€Łđ€Łđ€Łđ€Ł
- plemansJan 14, 2022Guru - Experienced User
got the rest of the data? yours only goes through channel 22 and misses the upstream and the ofmda channels
- UltraklassicJan 14, 2022AspirantThanks plemans for the reply. What would you like to see so I don't waste your time posting useless info? I appreciate all the input from everyone :smileyvery-happy:
- UltraklassicJan 14, 2022AspirantHere's a pic.
