Umbepalme
Apr 28, 2022Follower
Rbr40 and rbs20
Can anyone tell me if I will be able to use my high speed Netgear router CM700 and my two satellites RBS20 in Italy? I am moving in a couple weeks and if they work I am not going to sell them. Thanks, Umberto.
1 Reply
Maybe?
For the modem, it depends on the ISP there. You'd need to contact them to see what services they offer.
they might not offer cable and that modem might not be compatible with their services.
For the router. will it work? yes. Problem is that if you're coming from the NA (north america) region, the region is locked on your device. there used to be a way around it with telneting in and using the burnsku command. But that's been locked down. But if its not locked, you can change it to the EU region and it'll work fine. You just might need to check the power supply thats used there and use an adapter for power.
