PFi
Nov 01, 2024Aspirant
RBR40 and RBS40 generate different subnets for attached devices
I use RBR40/RBS40 mesh. Despite the fact that I have defined the subnet (192.168.0.x) for the LAN TCP/IP and directed to use Router as DHCP server with the starting and ending IP addresses within the...
- Nov 07, 2024
I have found the "rogue" DHCP. My VoIP device had the internal DHCP server enabled. I turned it off, and the issue went away.
Thank you very much for your help.
Nov 01, 2024Guru - Experienced User
Does the RBS show fully synced to the RBR on the RBRs web page?
Has a factory reset and setup from scratch with a wired PC and web browser been performed?
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Might try this with the RBS in same room or near the RBR and setup from scratch using this process:
- PFiNov 01, 2024Aspirant
Thank you for your response.
I am not sure what the "fully synced" means. The attached devices tab shows devices connected to both the router RBR-40 and the to the satellite RBS-40. Moreover, the devices with IP addresses from both subnets appear connected to both router and satellite.- FURRYe38Nov 01, 2024Guru - Experienced User
Fully Sync means the status shown on the RBRs web page shows GOOD or Wired for RBS that are ethernet connected.
Can you log into the RBS web page at it's assigned 192.168.0.# IP address?
Which devices are getting the different IP address from 192?
What Firmware version is currently loaded on the RBR and RBS?
