PFi
Nov 01, 2024Aspirant
RBR40 and RBS40 generate different subnets for attached devices
I use RBR40/RBS40 mesh. Despite the fact that I have defined the subnet (192.168.0.x) for the LAN TCP/IP and directed to use Router as DHCP server with the starting and ending IP addresses within the...
- Nov 07, 2024
I have found the "rogue" DHCP. My VoIP device had the internal DHCP server enabled. I turned it off, and the issue went away.
Thank you very much for your help.
PFi
Thank you for your response.
I am not sure what the "fully synced" means. The attached devices tab shows devices connected to both the router RBR-40 and the to the satellite RBS-40. Moreover, the devices with IP addresses from both subnets appear connected to both router and satellite.
Nov 01, 2024Guru - Experienced User
Fully Sync means the status shown on the RBRs web page shows GOOD or Wired for RBS that are ethernet connected.
Can you log into the RBS web page at it's assigned 192.168.0.# IP address?
Which devices are getting the different IP address from 192?
What Firmware version is currently loaded on the RBR and RBS?
- PFiNov 01, 2024Aspirant
The status is GOOD.
To that "rogue" subnet connected all kind of devices, such as TVs, security, a tablet, a VoIP phone, Roku, a speaker.The router firmware version is V2.7.4.24.
The modem is Netgear Genie CM1150V firmware version V4.12.04.
- FURRYe38Nov 01, 2024Guru - Experienced User
Do these rogue IPs show up on the RBRs web page for each of these devices?
Can you post a screen capture of the RBRs web page with the MAC addresses redacted out?
Have you attempted to turn OFF all of these devices and then check the RBRs web page for devices, then turn them ON, one at a time then check the RBR web page and device to see what IP address gets assigned? Graduate turn them on one at a time to check the RBR and device?
- PFiNov 05, 2024Aspirant
Thank you for the response.
As I mentioned earlier, the devices from both subnets appear connected to both RBR and RBS.
There are over 30 devices connected to the network, and it would be difficult to scrape screenshot from the information I would not want to share such as list of devices, MAC addresses, etc.
For the same reason turning OFF ALL of these devices would be impractical. Among them many IoT, security, HVAC, and other devices.
I suspected that either my HVAC system or security system had its own DHCP server and had created a separate subnet for its devices. However, that does not seem to be the case, as the HVAC and security devices are distributed across both those subnets.
CrimpOn
As I mentioned in one of my previous responses, I have over 30 devices connected to the Orbi mesh network.Of those about the third connected to the "rogue" subnet 172.27.35.x. The rest are connected to the "prescribed" subnet 192.168.0.x.
Of the devices on the "rogue" subnet about the equal number connected to RBR and RBS.
To answer you how the "rogue" addresses are listed on the "Attached Devices" page, just imagine that in the column "IP Address" you see two kind of addresses: one kind starts with 192.168.0. and another start with 172.27.35. and the are mixed in the order.
I have downloaded WireShark and will try it later, when I have a bit more time.- CrimpOnNov 05, 2024Guru - Experienced User
Thanks. Each device displays only one IP address? or do some devices appear two times in the display?
I am having a bit of confusion over how the heck the Orbi can communicate with devices in a different IP subnet.
- PFiNov 07, 2024Aspirant
