PFi
Nov 01, 2024Aspirant
RBR40 and RBS40 generate different subnets for attached devices
I use RBR40/RBS40 mesh. Despite the fact that I have defined the subnet (192.168.0.x) for the LAN TCP/IP and directed to use Router as DHCP server with the starting and ending IP addresses within the...
- Nov 07, 2024
I have found the "rogue" DHCP. My VoIP device had the internal DHCP server enabled. I turned it off, and the issue went away.
Thank you very much for your help.
CrimpOn
Nov 05, 2024Guru - Experienced User
Thanks. Each device displays only one IP address? or do some devices appear two times in the display?
I am having a bit of confusion over how the heck the Orbi can communicate with devices in a different IP subnet.
PFi
Nov 07, 2024Aspirant
- FURRYe38Nov 07, 2024Guru - Experienced User
Glad you found the issue. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
