Joined's avatar
Joined
Initiate
Feb 04, 2019
RBR40 and RBS40 wifi - Wishing to capture/monitor traffic/BW usage of connected wifi devices
Hello
Have had this model RBR40 RBS40 of Orbi for some time and am very  happy with its performance once I installed two corresponding satellite units. I am keen to capture the usage of each  wifi device connected to the Orbi base unit and the satellites. The Orbi base unit is set up as an AP. Ahead of the Orbi is a VDSL modem connected to the Internet. The VDSL modem provides the DHCP server for all  wired and wireless (wifi) connected devices on the LAN.  I note from looking at the ip table in the VDSL modem that all three  Orbi’s are assigned an individual IP address as expected. When I log into the individual  Orbi’s I can see the individual connected devices IP address but when I log into the VDSL modem I can only see the respective Orbi Ip addresses not the connected devices. My plan was to insert a monitoring  device to enable wireshark to capture all traffic. But I am guessing the Orbi NAT’s will not allow me to capture the wifi devices individually and since being a consumer product there will not be the option to disable the NAT.
i appreciate advice on what alternatives/ possible options I have to capture the individual wifi devices consumption “behind” the Orbi’s. I presume reconfiguring the network to change the role of the Orbi to a router rather than an an AP won’t help because the NAT remains. Any help appreciated since I wish to avoid replacing the Orbi’s. Chris
  • FURRYe38's avatar
    What FW is currently loaded?
    Have you enabled Traffic Metter? This only collects overall usage for the entire system. I don't believe Orbi separates it down by devices.
    • CrimpOn's avatar
      CrimpOn
      Furrye38 asked the right question: what is the make and model of the modem you are connected to?
      Something in your analysis may not be correct.  If the Orbi is in AP mode and the modem is providing DHCP to all devices, then all devices should appear in the modem DHCP tables.  Orbi's in AP mode perform no router functions.  They do not assign IP addresses.  They do not NAT.  They have no firewall.  etc. etc. etc.  So, if the modem DHCP tables do not contain your other devices, where did they get their IP's?
      Since my Orbi is not in AP mode, I cannot state for certain, however, my first attempt at capturing traffic would be to activate "Mirror WAN traffic to LAN port 1" on the Orbi debug page:  (IP of Orbi Router)/debug.htm)  Attach your Wireshark capture to port 1.
  • Joined wrote:
    ........... But I am guessing the Orbi NAT’s will not allow me to capture the wifi devices individually and since being a consumer product there will not be the option to disable the NAT.
    Completely agree with CrimpOn. Orbi in AP mode does not do any NAT. Only when you set Orbi in Router Mode it will do NAT.
    • CrimpOn's avatar
      CrimpOn
      I neglected to mention that besides mirroring WAN traffic to Port 1, Orbi's "debug screen" also allows capturing LAN/WAN traffic either to system memory or to a USB drive.  I have done this numerous times, although I do not leave it running for a long time.  To be honest, I have never tried saving to USB drive.  If I wanted to capture a substantial amount of data, I would probably try that first.  These capture files are zip files (compressed) and include LAN and WAN in separate Wireshark files, plus a bunch of other stuff.
      • CrimpOn's avatar
        CrimpOn
        Oh, fudge.  Also neglected to verify that RBR40 actually has a USB port.  Looks like it does not.  My bad.  Sorry.
