Roofus
Dec 13, 2021Aspirant
RBR40 and RBW30 satellite - poor connection with line of sight free and daisy chain on
My house has 3 floors with the RBR40 router on the middel floor in a corner of the house. Less than 30 ft away from the router is a satellite with a sheetrock wall in between them. Immediately above ...
CrimpOn
Dec 14, 2021Guru - Experienced User
Roofus wrote:
My house has 3 floors with the RBR40 router on the middel floor in a corner of the house. Less than 30 ft away from the router is a satellite with a sheetrock wall in between them. Immediately above that satellite (let's call this Sat-B) is another satellite (Sat-C). Straight down the hall from Sat-C is the final satellite (Sat-D). There is 30 feet between Sat-C and Sat-D with no barriers, it's an empty hallway.
The distant satellite (Sat-D in my explanation above) often moves to amber or red color and tries to reconnect and/or offers poor connection speeds. The Sat-D often is connect directly to the router which, to me, makes no sense given the walls and 150+ foot distance when there is perfectly good satellite (Sat-C) just 30 feet away.
The math is not working out for me. 60ft horizontally plus 15ft? vertically would compute to a diagonal measurement of about 62ft, not 150+.
No matter. Yes, satellite D should connect to satellite C rather than D. RBW30 satellites are designed to plug directly into wall outlets, which is often a poor location for WiFi radios. I like the suggestion to get an extension cord and try moving satellites around a bit to see if connections improve.
Roofus
Dec 14, 2021Aspirant
Should I change the transmit power (reduce it from 100%) to potentially force the far satellite (Sat-D in my example) to connect to another satellite rather than trying to connect directly to the router?
Is there an easy way to monitor the performance of a single satellite, other than the colored LED, so I can determine the impact of any location changes?
Thanks again for your help!
