primmyrose
Mar 17, 2022Initiate
RBR40 and RBW30
Hi all, I have 2 x RBR40 and 2x RBW30 Satellites. Currently they are being used as Acess points as we are unable to use them with our provider as the main router. For some reason I currently...
primmyrose
Hi thanks very much for your response.
I'm not sure its what I meant though.
1RBR 40 is broken and 1x RBW30 is broken
I have 1RBR40 and 1RBW30 remaining but these do not provide coverage for the whole house.
which models can I buy to add to the network?
Hopefully that is clearer. the house is made of concrete......
Mar 18, 2022Guru - Experienced User
compatible models with the RBR40 are:
RBS20
RBW30
RBS40
RBS40V
RBS50
RBS50Y
Keep in mind the 50 series have the wider backhaul the 40 series router doesn't support. They do work, they just operate at the narrower backhaul.
You can also use the EX7500/EX7700/EX8000. they don't integrate with the orbi but do work.
