greggkast
Dec 26, 2020Aspirant
RBR40 and Tivo WIFI 5 USB Adaptor
I am new to this site, but have been a long term customer. I have a Tivo Lux, that I am using the Tivo WIFI 5 USB Adaptor. This adaptor only works on the 5 ghz network. However, it is ...
greggkast
Thanks for your reply and the link to the Amazon site for this device.
Great point, about at what point the setup is failing.
It is failing at the connection point.
After I enter the password to my SSID, it fails.
Im sure just like anyhting, there is a bad one in every bunch and I might have received a bad adaptor.
I will keep this thread updated as things progress.
Thanks again,
Gregg
CrimpOn
Dec 26, 2020Guru - Experienced User
greggkast wrote:After I enter the password to my SSID, it fails.
Does it display the password, or just show those stupid "*" or dots?
- greggkastDec 26, 2020Aspirant
The setup interface shows the password as it is entered.
G
- CrimpOnDec 26, 2020Guru - Experienced User
greggkast wrote:The setup interface shows the password as it is entered.
Well, fooey. I was hoping for "caps lock" being on or some obvious keyboard problem. Seems like time to beat on the Tivo support line.
- greggkastDec 27, 2020Aspirant
it comes down to turning over more rocks to find what you are looking for.
thanks
g
