Entnx
Aug 22, 2020Aspirant
RBR40 Anywhere access
Cannot enable anywhere access. Keep getting this mewsage "This Netgear device is already registered with another account". Noticed this issue after the router update. Was working fine before the updates.
Has a factory reset and setup from scratch been performed since last update?
- MstrbigMaster
Entnx wrote:
Cannot enable anywhere access. Keep getting this mewsage "This Netgear device is already registered with another account". Noticed this issue after the router update. Was working fine before the updates.That's very strange. You had no problems, then got an Orbi firmware update, and now it shows registered to another account? Freaky.
