Baz80
Apr 05, 2022Aspirant
RBR40 base station does not connect at 5Ghz only 2.4GHZ. Issue connecting apple devices
Hi, I am having issues with my RBR40 base station. V2.7.3.22 (base + 2 satellites). Issue: connecting 5GHZ on base station. Only devices connecting 2.4GHZ band will work. Issue not faced with Sat...
Baz80
1- It is connected to Service provider's fiber modem. This was same setup since last 4 years.
2- Yes I did factory reset. Can you please clarify what do you mean by "testing it in its stock configuration"?
3-Thanks for pointing to post in Orbi Forum. Do you suggest I delete this one and post a new one under Orbi Forum?
Apr 05, 2022Guru - Experienced User
what fibre modem is it? model?
No you won't need to move/delete it. Already done.
by stock configuration I mean test it without changing anything on the install other than whats needed to be changed to get it run.
- Baz80Apr 05, 2022Aspirant
1-It is Alcatel-Lucent Model I-240G-D
2-"test it without changing anything on the install other than whats needed to be changed to get it run": Yes I did this but still same issue. All devices are able to connect to any of the two satellites, but for the Orbi main unit in ground floor, only 2.4Ghz devices can connect.
Thanks for your support
- plemansApr 05, 2022Guru - Experienced User
the gateway has some routing functions built in. Try going into it and adding the netgears IP address to its DMZ.
I can try logging in gateway and adding netgear IP address to its DMZ. However, as I explained, after 4 years of running perfectly, this issue occurred suddenly impacting the 5Ghz band devices only. I even tried to change the 5Ghz channel incase I have interference from other AP's from nearby neighbors, but it did not resolve the issue.
