farmboy3000
Dec 10, 2022Star
RBR40 Braindead!
My orbi stopped working yesterday and I haven't been able to get it working again. When it powers up only the little yellow light on the back comes on. No white light on the top. I have attempte...
CrimpOn
Dec 10, 2022Guru - Experienced User
It has been months. As I recall, when the file transferred, there was a 'progress bar' on the screen.
After I went through all that, people mentioned nmrpflash: https://github.com/jclehner/nmrpflash
I believe that one of the advantages (claimed) for that is it does the timing automatically. If I had another spare Orbi, I would flash firmware on it just to see what happens.
farmboy3000
Dec 11, 2022Star
Thanks CrimpOn! I'll give it a shot.
- farmboy3000Dec 11, 2022Star
I didn't have any luck with the nmrpflash program. I was able to list the ports, but it couldn't flash to any of them. I'd always get an error "Ethernet cable is unplugged". I tried using the mac address as well and blind mode.
I tried TFTP about 20 times with different timings and couldn't get that to work either.
Unless anyone has other suggestions I think I give up.....
