Pistol_451
Nov 11, 2024Aspirant
RBR40 bricked?
Hi, hoping someone might be able to help me resurrect my RBR40. A while ago it started having problems, wireless devices lost their internet access but wired connections still worked. Turning it of...
Nov 11, 2024Guru - Experienced User
With the RBR disconnected from everything, WAN and LAN devices, try a 30-30-30 reset on the RBR and see if this brings it back?
Pistol_451
Nov 20, 2024Aspirant
It won't even do a 30-30-30 reset now, it seems completely unresponsive to anything at all. Think it must be totally dead đ
- FURRYe38Nov 20, 2024Guru - Experienced User
Most likely.
If you need another RBR, try looking at places like ebay for shopgoodwill for good used units.
Maybe time to upgrade to something new as well.
Good Luck.
