efouquet
Dec 27, 2020Aspirant
RBR40 cannot upgrade to firmware V2.6.1.36
Today I got an email telling me an update is available. I tried the manual update method and that fails with an Internal Sever Error (500 error) in the browser. Here's my current setup as far as fi...
- Dec 27, 2020
You might try Safari or Opera browser to see if the newer FW can br applied. Is there a Windows PC around? If so, Try this.
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
Need to press the reset button for 30 seconds then release, then it send to PUT the command and upload the FW. You could apply either a newer or older FWversion.If not, I would contact NG support to see if they can help you out more.
Dec 27, 2020Guru - Experienced User
What version of FW is currently loaded on the RBR?
