efouquet
Dec 27, 2020Aspirant
RBR40 cannot upgrade to firmware V2.6.1.36
Today I got an email telling me an update is available. I tried the manual update method and that fails with an Internal Sever Error (500 error) in the browser. Here's my current setup as far as fi...
- Dec 27, 2020
You might try Safari or Opera browser to see if the newer FW can br applied. Is there a Windows PC around? If so, Try this.
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
Need to press the reset button for 30 seconds then release, then it send to PUT the command and upload the FW. You could apply either a newer or older FWversion.If not, I would contact NG support to see if they can help you out more.
Poper70584
Dec 31, 2020Aspirant
Has a solution been found for the updates? would like to apply current security patches that show to be available. My RBR40 is having same issue. I'm on the same version v2.5.1.22 set to auto update. The satellites are v2.5.1.16. When checking for new updates from router update page it still shows no new firmware version available.
- FURRYe38Dec 31, 2020Guru - Experienced User
So have you downloaded the FW files from NGs web site and applied them to the RBS first then RBR lastly using a wired PC and web browser? IE11 or Firefox?
- efouquetDec 31, 2020Aspirant
Poper70584 wrote:Has a solution been found for the updates? would like to apply current security patches that show to be available. My RBR40 is having same issue. I'm on the same version v2.5.1.22 set to auto update. The satellites are v2.5.1.16. When checking for new updates from router update page it still shows no new firmware version available.
Not yet. I still haven't tried the Windows TFTP firmware upgrade workaround that was suggested. I'll try to do that tomorrow and report whether or not that worked out for me.
Try using the RBRs web page first. You can even log into the RBS web page as well. I would do this first. Get the RBS updated first, then the RBR lastly. Be sure unpack the .zip files you download.
- efouquetDec 31, 2020AspirantI tried that, didn’t work. It was resulting in a server side 500 error.
- Blanca_OJan 17, 2021NETGEAR Employee Retired
Hi, All,
The issue has been forwarded already to engineers. We will let you know for any updates.
Blanca
Community Team
