efouquet
Dec 27, 2020Aspirant
RBR40 cannot upgrade to firmware V2.6.1.36
Today I got an email telling me an update is available. I tried the manual update method and that fails with an Internal Sever Error (500 error) in the browser. Here's my current setup as far as fi...
- Dec 27, 2020
You might try Safari or Opera browser to see if the newer FW can br applied. Is there a Windows PC around? If so, Try this.
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
Need to press the reset button for 30 seconds then release, then it send to PUT the command and upload the FW. You could apply either a newer or older FWversion.If not, I would contact NG support to see if they can help you out more.
Poper70584
Dec 31, 2020Aspirant
Has a solution been found for the updates? would like to apply current security patches that show to be available. My RBR40 is having same issue. I'm on the same version v2.5.1.22 set to auto update. The satellites are v2.5.1.16. When checking for new updates from router update page it still shows no new firmware version available.
Blanca_O
Jan 17, 2021NETGEAR Employee Retired
Hi, All,
The issue has been forwarded already to engineers. We will let you know for any updates.
Blanca
Community Team
- FuseRulesJan 18, 2021Tutor
Thanks!!
- RpenhaleFeb 04, 2021AspirantSame issue here, no means of upgrading beyond 2.5.1.22, tell me 2.6.2.104 is available but using app, Rui, manual update via Rui or TFTP don't work, router goes offline for about 30 mins every time with pulsing white lights and eventually back to 2.5.1.22, I even paid £54.99 for support but this was only when it looked like the router was bricked so have asked for a refund. Router still under hardware warranty so not sure how to proceed as not currently fit for purpose if it can't be updated.
