Techfarmer
Jul 14, 2020Aspirant
RBR40_Can't login to Admin directly
RBR40_Firmware V2.5.1.16 - Access thru App works fine - Get login screen thru 192.168.1.1 - User name / password accepted without error, but bounces back to login - Sometimes get "not secure"...
Jul 16, 2020Guru - Experienced User
Has a factory reset and setup from scratch been performed since last FW update? One maybe needed if you see log in problems.
Walk thru the setup wizard and input correct admin and new password info. Be sure to write down all important infornation.
Be sure to clear out all browser caches as well prior to going to the admin page...
