ORBI07
Jan 04, 2018Follower
RBR40 Can't upload Etc.
First, it acts like this is an invalid model#. Which I got from the registration e-mail. Not confidence inspiring. 2nd, I can not connect to tech support (probably pretty busy).
Just installed this Orbi Router. Worked great when we first hooked it up. Has one satellite unit. Was streaming on a Vizo TV I-phones, Android, I-mac. etc. all working fine.
Now, I only get 1 bar instead of 5 on the TV, and I can not send anything out larger than a text file either on hardwired or wi-fi. Photos etc. will not go.
Tried all the ususal synch and reboot. Is this more problems with the firmware update? If so, what version should I attempt to install? Or, should I just box this back up and return it to Best Buy. After reading all the problems in other threads, I am thinking I might just want to bail and not waste time. Too bad 'cause the coverage is nice.
1 Reply
- DarrenMSr. NETGEAR Moderator
What version of firmware are you on?
DarrenM
