Dave3301
Apr 01, 2021Initiate
RBR40 changed internet service provider and now can't access secure pages
We have an RBR40 wireless mesh system with two satelites. Yesterday we switched out internet from Spectrum to ATT. We made no changes to the router, simply switched the ethernet cable from the Spect...
- Apr 01, 2021
att tends to use modem/router combo devices.
did you try using the orbi in access point mode?
How to fix issues with Double NAT | Answer | NETGEAR Support
Apr 01, 2021Guru - Experienced User
Dave3301
Apr 02, 2021Initiate
Thank you, thank you, thank you!!!!! Changing the ATT modem to Bridge mode fixed my problem. Not sure why the first ATT tech I spoke to for 2.5 hours did not know to do this.
