Biigdaddio
Jun 16, 2020Aspirant
RBR40 connection drops and low "max rate"
TL;DR: While trying to fix my signal dropping, I found my max rate (though-put?) seemed incredibly low. Is it me or is it Netgear or is it InSSIDer? I have had frequent, intermittent signal drops ...
- Jun 24, 2020
Well, I've had a stable connection now for three straight days so I think this is solved. Between the instrux from FURRYe38 and shutting down the Chromecast, it looks like this is solved.
Jun 16, 2020Guru - Experienced User
https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
- BiigdaddioJun 16, 2020Aspirant
V2.5.1.16 No new firmware version available
No modem. Fios ONT
Home about 2000 square feet but it is old and the walls are thick so getting wifi everywhere is the challenge. Sats are about 30 feet away, but one of them is on another floor and the walls are lathe and plaster so...
Channels are manual and set to not be on the same as my many, many neighbors. Don't recall which channels at the moment but the apps I use show them as being clear of most interferance, which is why I chose them. The signal is at least twice as strong as any neighbor's network per Wifi Analyzer.
I've seen no difference since disabling MUMIMO and beamforming, etc. It might even be a bit better, frankly. I have re-enabled them to test. I don't see WMM. Will see how it goes tonight.
My original post noted that I did a hard reset and setup after the last firmware updated. I don't have daisy chain or any of the other items you mentioned enabled. I changed the preamble to short (was auto). IPV6 is greyed out in my menu.
- BiigdaddioJun 19, 2020Aspirant
So, FURRYe38 I did pretty much everything you mentioned. In addition, I came upon a really easy tool for monitoring the internet connection. It is just a Chrome browser extension called Internet Connection Monitor, which pings Google every three seconds, alerts you when either or both of the wifi and the router's ISP connection goes down, and keeps a log.
Telling the poor CSR I was doing this seemed to be enough to finally get someone to come out and look at it. And apparently only when a tech is onsite will the engineers in the data center pay attention (somewhat). The tech translating the engineer's texts was pretty comical but finally we did get from the engineer that there was a "bad cross cennction" issue. The tech was amused: he knew what a cross connection would be if there were copper involved, but in terms of the software backbone managing the optical, not a clue.
Anyway: it worked for the connection. There have been no drops from the ISP for about 36 hours, a record.
For the Orbi, the story is not quite as positive, but nearly. I only had one drop from the Orbi wifi all day. Another record. Either FURRYe38 suggestions helped or getting a more stable Verizon connection helped or probably both. I'm cautiously optimistic. Thanks for the help.
- BiigdaddioJun 20, 2020Aspirant
I spoke too soon.
Four drops on the Orbi overnight, 15-20 seconds each. Then two more just since I started writing this. I wonder if the Eero is still on sale. Only problem there is the need for a switch in the TV room as I like having wired as much as possible.
- FURRYe38Jun 20, 2020Guru - Experienced User
Glad you made progess.
Biigdaddio wrote:So, FURRYe38 I did pretty much everything you mentioned. In addition, I came upon a really easy tool for monitoring the internet connection. It is just a Chrome browser extension called Internet Connection Monitor, which pings Google every three seconds, alerts you when either or both of the wifi and the router's ISP connection goes down, and keeps a log.
FURRYe38 see the attached. Serentiy is the Orbi so there are three of them. Dedicated is the Nighthawk router that is connected to Fios and then supplies internet to the Orbi. Hidden SSIDs are I'm sure Roku and Chromecast (the first CC is surely the one built into the TV I'm sitting near). Every time I change the channel on the routers, Hidden SSID follows to that same channel. Print server is also mine.
The connection log is for the Orbi. The log for Dedicated (connected to fios) shows three drops since last night, two of them in quick succesion this morning. Those drops don't correspond in time to the Orbi drops, but the two monitors are likely pinging at different times. Since the drops are only for a few seconds on the main router the Orbi monitor could have missed them. The monitor is pretty surely connected to the satellite. I may try setting it up on the base unit to see if maybe the backhaul is the issue.
